deny (ip-snmp acl)
      Creates a deny SNMP MIB object traffic rule. Use this command to specify
        the match criteria based on which SNMP traffic is denied
            - Access Points:
               AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP7602, AP7612, AP7622, AP7632,
               AP7662, AP8163, AP8533.
            - Service Platforms:
    Syntax
      deny [<IP/M>|any|host <IP>]
    Parameters
              | deny [<IP/M>|any|host <IP>] |
              Configures the match criteria for this deny rule
                  - <IP/M> – Specifies a network address and mask in the
                    A.B.C.D/M format. Packets received from or destined for this network are
                    dropped.
                  - any – Specifies the match criteria as any. Packets
                    received from or destined for any address are dropped.
                  - host <IP> – Identifies a host by its IP address.
                    Packets received from or destined for this host are dropped.
      nx9500-6C8809(config-ip-snmp-acl-test)#deny 192.168.13.0/24
      nx9500-6C8809(config-ip-snmp-acl-test)#show context
ip snmp-access-list test
